Dual to Quad LNB upgrade
Discussion in 'Satellite TV, Sky TV & FreeSat' started by MrR, Aug 15, 2013.
  1. MrR
    MrR
    Jul 16, 2005
    88
    North of Cardiff
    +7
    I'm looking to upgrade the LNB on my SKY dish from a twin feed to a Quad feed LNB so that I can run cables to my Panasonic VT65 plasma which has twin Freesat connections on it.
    My local TV mast has only 15 TV channels on it so there are occasions when the SKY box is recording 2 channels (eg. SKY 1 and Alibi HD) and I wish to watch another such as DAVE at the same time.
    What would be the best option in getting this done; going to
    SKY - as it's their dish and LNB that would be upgraded. Will sky do this as the additional cable would only be going to a Freesat connection.
    Independent installer - how much would they charge compared to SKY.
    DIY - How difficult is it to swap and realign the LNB
    I've got a SKY+HD box currently and have no intension of having a multi-room skybox so the extra cables will be for Freesat only.
    Thanks for any help.
  2. spamsingh
    spamsingh
    May 18, 2009
    277
    +18
    I did this a few years ago. It is very simple to do yourself.
    I bought an eight output lnb. Simply unscrew the current F connectors to the LNB. Swap the LNB out and reconnect.
    My dish was only 3 metres off the ground so it made the job easier.
    Dish should already be aligned. Just copy the skew for the current LNB.
    It literally took me less than 15 minutes to do.
  3. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    Sky won't do it, you 'll need to ask how much installation would cost locally, or you can do it yourself quite easily.
    Simply get the new LNB and replace the present one - though it's odd that it isn't a quad already.:confused:
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Just to add that you should remove mains supply to the PVR's before messing about with the LNB connections.
    Although unlikely, the last thing you need is an electric shock whilst at the top of a ladder! :eek:
  5. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    If your dish was fitted by Sky for digital satellite it is highly unlikely that it has a dual lnb - Sky only used dual lnbs for a very short time many years ago before SD Sky+ days and dual lnbs for Sky dishes have not been made since then.
    Can you actually see the lnb and count the number of outlets (not just the number of cables)?
  6. MrR
    MrR
    Jul 16, 2005
    88
    North of Cardiff
    +7
    Thanks guys, I'll take a look at the LNB on the weekend.
    I haven't noticed any other unused connectors on it unless there is a cover over them.
    If anything goes wrong I'll call Sky to repair everything and plead innocence:devil:
  7. logiciel
    logiciel
    Feb 2, 2008
    53,105
    UK
    +5,759
    Agreed - it will have a quad LNB.
    I was only agreeing with you on that one.:blush:
  8. HD sceptic
    HD sceptic
    Apr 1, 2009
    814
    28
    Glasgow
    +81
    It's your dish and LNB, not theirs
    Depends how comfortable you are working at height.
    TBH, I did exactly the same myself a few weeks ago, bought the cable, fitted the plug, climbed the ladder, and just screwed it into a spare socket on the LNB, the hardest bit was tacking the cable to the wall afterward.
  9. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    For the record, Sky have never supplied a "dual LNB".
    LNB mysteries explained - part 1
    I mention this in case anyone is tempted to order one, when they need a "twin-output LNB" (or vice-versa).
    There's a few web sites that list them incorrectly, so beware. In addition, a "dual LNB" in America is something else again!
  10. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
  11. Aamii2892
    Aamii2892
    Feb 1, 2011
    35
    11
    Birmingham
    I thought Sky have been fitting Quad LNB for a while haven't they. Got a Quad on my Dish fitted by the Engineer but only two being used for Sky+HD box.
  12. winston2010
    winston2010
    Jun 28, 2010
    1,891
    London
    +187
    Sky don't use engineers for this. He/she was an installer.
