Question Dual Sub placement
One more thing
My room is 4 x 4.5m. Does anyone know what would be a good starting point to try dual sub positions? Is in the alcoves a good place?
fatboy frank
Looking at your layout I'd maybe suggest front left and right positions in the corners but assume the door front right will prevent that ? So I'd go inside of your L & R front speakers equidistant if possible. Failing that, maybe front left and diagonally opposite (rear right) if that's possible?
One more thing
Thanks, will give that a try. As I have ARC on anthem do you think I could put them in more conveniant positions and let ARC adjust? I am I right in thinking where there is a null the EQ wont do anything to rectify?
fatboy frank
To be honest I have never had an Anthem so not really in a position to comment on how ARC will work, might be worth asking in the Anthem thread/forum ? Usually having dual subs helps with nulls as one sub fills in the other ....... if that makes sense?
Not sure what you mean by more convenient position (as per your diagram) ?
Where is your AVR located, usually try to limit cable run as much as possible and if at all possible I try to avoid EQ'ing to death, better placement and treatment is preferable ...... but not always possible.
