Dual Stereo Integrity HT15" DIY Thread
Discussion in 'DIY Speaker & Subwoofer Building' started by MartinGR, Feb 27, 2014.
  1. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    I suppose this is the start of a DIY thread, so get ready for lots of questions:thumbsup:
    Thanks to 3Hz I have two drivers on their way. Im planning a DIY using these two SI HT 15" dual 4ohm subs wired to 2ohm each and one ran off each channel of a Cerwin Vega CV amp.
    Are the figures quoted on the Cerwin Vega website RMS? i.e. 2x900W RMS @ 2ohm for the CV1800, and 2x1400W RMS @ 2ohm for the CV2800?
    Ive modelled a 75L sealed box (one driver per box) in Win ISD, and with 900W (CV1800 amp) it hits xmax at 14Hz, but with the 1400W amp (CV2800) it will hit xmax at 32Hz, so the question is, am I better off going with the smaller Cerwin Vega CV1800 amp as a better match for these drivers?
  2. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    If you reduce the box size it will increase the power needed to get to XMax at 32Hz (or any given value) which should mean that the XMax points drops lower.
    It may get a bit 'boomy' in a smaller box, though?
    I would be tempted by the CV1800 and run it in 2Ohm stereo for 900w per driver in the 75L box, just for safety. I think the XMech is about low-30s mm - what Hz do you reach that sort of excursion with this configuration? (XMax is pretty much the limit of 'clean' and linear output but you are technically safe up to XMech.)
    System roll-off should reduce output down low, and there is not that much content going that low and really loud, so you should be fine...
  3. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Thanks MemX:smashin:
    I don't think I want to go any smaller than a 75L box. Ive had another look at Win ISD, and with the CV1800 (2ohm stereo 900w per driver) cone excursion is 27.5mm @ 5Hz.
  4. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    if you stick it in a 75l cab it will take 800w rms to hit its xmax at 10hz, my advice dont worry just get and cv2800 and you will have loads of headroom.
    xmax is 22.5mm and xmech is 40mm i believe.
  5. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    How are you finding sound quality from your CV 2800 scottthehat? Have you done a fan mod?
  6. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    finding it very very good, (in my op a step up from the nu3000 in everyway) I have done the fan mod. mine has 2x 80mm fans at back and 2x 60mm at front.
  7. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    Good stuff, the CVs are -3dB at 5Hz, IIRC, so I don't think the drivers would receive the full 900w by that point anyway, if I understand it correctly. (??)
    Headroom is good, yes :)
    XMech was tested to be about 35mm inward by Josh Ricci on data-bass, IIRC, so I've designed mind round that!
  8. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    That's interesting on the x mech because no the site they state 43mm
    Stereo Integrity | HT Subwoofers
  9. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Looks like im swayed more towards the CV2800 now, as you say headroom is good:)
  10. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    Headroom is good it always the amp to run easier and if you have any eq that will use some.
  11. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    They do indeed!
    Check out the link to the DB forum at the bottom of that page, though:
    Data-Bass
    and
    • Thanks Thanks x 1
    • Useful Useful x 1
    • List
  12. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Drivers arrived yesterday, and order has been placed for the Cerwin Vega CV2800 amp. Things are starting to progress nicely with the DIY:clap:
    • Like Like x 1
    • Thanks Thanks x 1
    • List
  13. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Now the build is complete, its about time I updated this thread:smashin:
    Subs arrived:
    ..... then the boxes arrived from Gordy:
    .....and this lot arrived from CPC:
    The CV2800 arrived and the first job was to upgrade the Jamicon fans to Papst 8414ngl's (which are literally silent) using the factory spec terminals which were ordered from CPC:
    IMG_0844.JPG IMG_0858.JPG IMG_0864.JPG IMG_0866.JPG IMG_0884.JPG IMG_0886.JPG
  14. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Mat black vinyl was placed over the front rack mounting lugs to make the holes less obvious:
    The amp mods were now complete, so I moved onto the boxes themselves. Although Gordy builds an excellent sturdy box to any spec you want, people have complained about being able to get a good finish on them, particularly when using a gloss black finish. To get over this I had the sides and top of the boxes laminated with 6mm MDF, which was glued with mitred edges, so that there are no screw holes or joins on the flat surfaces to try and hide. The boxes were then covered in 4 coats of PVA to seal them, with sanding between each coat:
  15. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Boxes all sealed, sanded and ready to go to the bodyshop for paint:
    The boxes are being built as downward firing, so feet were needed to give the required clearance from the floor to avoid the 'choke' effect. 85mm timber cube feet were sourced from a furniture supplier, and these were wrapped in walnut vinyl to tie-in with the Dali's and other furniture in the living room:
    ......the finished article:
    ....and now all eight complete:
  16. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Next up was to make all the cables and terminals, which involved soldering all ends, heat shrinking and sealing the cables to ensure there was no air leakage through the cables themselves as they pass through the boxes. Attention to detail is what this build is all about!!!:
    The boxes were sealed on the internal corners prior to being insulated. This probably wasn't necessary, but I wanted to ensure minimal air leakage:
    The feet were attached using M10 bolts, and silicone sealed on the inside. 10mm foam underlay was glued to all internal faces and gasket tape applied to the sub mounting flange (these boxes are damned air tight!!:
    Plenty of low modulus silicone was applied where the cable passes through the boxes to the banana plug terminal plate to ensure an air tight seal: IMG_1160.JPG
    3lb of polyfill was then placed into each box: IMG_1161.JPG
  17. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    The subs were bi-wired, resistances checked and then prepared for dropping into the boxes:
    Sub completely mounted using black allen bolts and T-nuts:
  18. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    And now for some finished article pictures:
    IMG_1167.JPG IMG_1168.JPG IMG_1169.JPG IMG_1170.JPG IMG_1171.JPG IMG_1172.JPG IMG_1177.JPG IMG_1178.JPG
  19. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    To say im impressed is an understatement, they sound absolutely awesome and the finish is unreal:thumbsup:. A huge huge thanks to the folks on this forum, if it wasn't for a certain few individuals this build would never have happened and id have been content with my BK XXLS400;).
  20. gav21041981
    gav21041981
    Oct 12, 2012
    682
    43
    sheffield
    +180
    Awesome build. Just shows what can be acheived
  21. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    What a lovely job you have made of these Martin you should be proud of yourself at the standard of finish & detail you have achieved.What has been the final cost? whatever it was you could not have bought a pro made sub for anywhere near what you have paid which gives a huge amount of self satisfaction and knowing it's all your own work.:thumbsup:
  22. 3Hz
    3Hz
    Jan 8, 2011
    292
    London
    +54
    Wow Martin, they look fantastic! With that much attention to detail I should have got you to build mine! :D
    Good to hear you're enjoying them.
  23. The Liberator
    The Liberator
    Mar 17, 2014
    146
    SE Ireland
    +51
    Great job :thumbsup:, very nice set up, like the 6mm MDF idea to get a perfect finish.
  24. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Thanks Gav
  25. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Thanks for the kind comments. The total cost came in at just under £1500, but like you say, commercial subs at this level would be considerably more.
  26. kbfern
    kbfern
    Aug 17, 2002
    17,929
    Wolverhampton
    +6,093
    You would be lucky to get 1 sub for £1500 of this caliber let alone 2 so very well done.
  27. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Thanks very much Tim. I'm holding you the most responsible for all the hard work and expense I've had to endure, as if it wasn't for your group buy, I wouldn't have done it:smashin:. It was all worth it though, and I definitely owe you a pint if you ever local:thumbsup:
  28. MartinGR
    MartinGR
    Dec 23, 2012
    69
    +10
    Thanks, the MDF laminate worked out excellent and there's no risk of any filler sinking and lines/holes becoming visible.
  29. 3Hz
    3Hz
    Jan 8, 2011
    292
    London
    +54
    I thought you were bored and needed some excitement in life so I had to... :D
    My pleasure Martin. Well done on such a fantastic build. :clap:
  30. MemX
    MemX
    Feb 15, 2013
    3,724
    +1,206
    Nice job!! :thumbsup:
    Great finish on those and they fit right in - I love the little feet, they give them 'character', like they're going to waddle over and try to sit on your lap like a pet at any moment :laugh: (It is early, I've not yet had caffeine, bear with my strange thought processes... lol)
    May I ask what spec the amp fans are? (cfm, dB, etc) I've got my CV5000 in the same room at the moment and my background noise level with it on is something like 50dB... :laugh: It's driving me nuts! I'm going to put it in a cupboard and run cables through the wall lol
