Dual Spares
D
dreamrose
I wonder if anyone knows where I can pick up spares for an old DUAL turntable?
Thanks.
DR
Cable Monkey
Best bet is to post the model.
D
dreamrose
Sadly, it's only a very old Dual CS505 Mark 1 - The part that holds the cartridge and goes into the headshell has snapped one of the plastic lugs.
DR
Cable Monkey
And it just so happens I've got a 505-1 or 505-2 sitting in my garage. I shall dig it out and take a look for you.
Similar threads
