Flektor
Ok, a strange one this (but perhaps not) so here goes.
I have a pc with 3 hard drives, two 2Tb and one 4Tb. Now that the 4 is used for storing media files and backup files for Windows 7 it gave me the opportunity to install Windows 10 o/s on the now available second 2 Tb drive. I can now choose at boot up which system I want to use. I have a SB Audigy 2 with external interface box which I use with Win 7 and that works a treat but on Windows 10, even though the sound level indicators show sound is playing, there is nothing from the speakers. Does anyone think there may be a problem putting another sound card in the case, installing the drivers (which will happen once Windows detects the second card) and simply disabling the Audigy 2 in Windows 10 control panel and using the new card instead. I would disable the new card under Windows 7 as I still want to use the midi etc connectors on the Audigy 2
