dual sky boxes?
Discussion in 'Sky Digital TV Forum' started by googlybear, Dec 4, 2004.
  1. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    i am looking to diy a sky multiroom setup. I have a cable splitter from a single LNB ( kind of like the aerial splitters used in the old days) and was wondering if i feed this to a second box will it work or will i need a dual LNB?
    I think it should work like a normal tv aerial gets split to watch in multiple rooms. Can anyone enlighten me?
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    Googlybear
    Best using a double or quad LNB. They are not too expensive either :thumbsup:
  3. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    where do you get these from, how much are they and will i need a sky engineer to fit it for me?
  4. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    +225
  5. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    The dish is not high. Is it just a matter of taking off the old one and putting on the new one or will it need to be re-aligned?
  6. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    +225
    Shouldn't be too hard but remember before starting take both the power cable and the coax cable out of the digibox.
    If your not sure get help! I'm just a ladder holder :p
  7. gbmitie
    gbmitie
    Apr 25, 2001
    1,115
    48
    republic of ireland now
    +56
    1. U cant split a satellite signal.
    2. Get a quad from ebay, a lot cheaper, make sure it is suitable for the dish u are putting it on.
    3. a quad is heavier than a single so the arm may sag ever so slightly, just be careful.
    good luck
    gbmitie
  8. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    Wouldn't you need another subscription and sky card as well, unless you are using a freeview card in one room?
  9. googlybear
    googlybear
    Nov 10, 2004
    169
    16
    ok here goes
    You can split a satellite signal using a power pass through splitter. I have fitted this now and have one cable going downstairs (on the power pass through) and the other upstairs to a second digibox. I can receive the free to air channels except itv but if i want to watch upstairs i just take my viewing card with me.
    All in all a job well done me thinks :clap:
  10. gbmitie
    gbmitie
    Apr 25, 2001
    1,115
    48
    +56
    hi, lost my pc to bsod, where could I get a power pass through splitter and how much should I expect to pay?
    thanks
    gbmitey
