dual sim d500
Discussion in 'Mobile Phones Forum' started by welshboy, Jul 30, 2005.
  1. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    I would like to hear your opinions on the dual sim i want to have both an o2 sim card and an orange sim card is i9t easy to swap sim cards or are they both in at the same time and if someone phoned either of the numbers would the phonecall still come through and where is the best place to get one of these and how much will it cost and is it best to let someone with experiance to fit it or is it easy enough to do.
    Cheers.
  2. Dubster
    Dubster
    Mar 14, 2004
    1,114
    Down South
    +113
    Youll need to switch the phone on and off for the dual sim holder to switch over.So when you want your o2 (orange already on) on you will have to turn the phone off then on again.Any calls for your orange sim (when o2 on) will go to your voice mail,same vice versa.
    ebay is the best place to go and should cost around the £10 mark.Fitting is pretty easy but some dual sim holders can be a bit more fiddly.
    *easy* http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=67966&item=5793170934&rd=1
    *fiddly* http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=67989&item=5793645487&rd=1
  3. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    Thanks for the info.
