Quantcast
Dual Recording on Sky Plus
explicitlyrics
For those of you who dont know - here is how to get dual recording working on all sky + boxes.
Put the box in standby
Unplug the box form the wall power socket
Leave unplugged for 1 min
Hold BackUp and whilst holding plug the sky+ back in
Keep holding the BackUp button for another 10 seconds or so (all 4 lights on the box should turn on)
Wait 5mins or however long it says.
When its finished, wait 10seconds and turn the box back on.
You will now have new firmware and a sky+ box that can dual record
D
DTS Rocks !
Can you please explain 'Dual Recording',as my Sky+ box does that anyway doesnt it ?
explicitlyrics
Nobody asked I had just seen somebody ask why it wasnt working. Most Sky + boxes should do dual recording atm (record 2 channels at once) but some old ones wont and you need to upgrade the firmware for this to happen.
LDJ
And a box with much worse software than before you followed these instructions!
Be prepared for missed recordings, dropped series links, failed recordings, incorrect recordings, system crashes and a whole host of other joyous failures! :laugh:
explicitlyrics
Oh, lol ive never had any problems with it at all - it just seems to make the box run faster - but watch out for that then :p
Techno Freak
I upgraded my software the day it was delivered ( mid January ).
I was apprehensive after reading all the posts on crashing and missed recordings with the updated software - but.....
In 4 months I have had no failed recordings, no broken series links and no problems.
I record about 10 hours a week and a surprising amount are dual recordings.
D
DaveP
I'm intrigued by this! Do you only WATCH 10 hours a week or do you actually watch "live" television?
I tend to record everything I watch!
Dave
D
DaveP
Originally posted by DTS Rocks !
If you are watching it,why record it as well ? ?
Doh!!!
I watch it after or during the recording.
No Red Dots and FF through the adverts!
Dave
Similar threads
