Dual layer drive
Discussion in 'Desktop & Laptop Computers Forum' started by bogart99, Apr 26, 2007.
  1. bogart99
    bogart99
    Jan 17, 2007
    944
    France
    +62
    Trying to back up my entire copy of DVD films using DVD X Copy which works fine. I have now arrived at the point that the remaining films are over the capcity limit of a single DVD. I dont want backup copies spread over 2 discs or compressed to much so is a dual layer drive the answer. If so is it straightforward to use, ie will DVD X Copy see the setup as a dual layer and not try and compress it or spread it over 2 discs?
  2. RedRooster
    RedRooster
    DVD Shrink will do the job, and its free.
    Be warned, most dual-layer discs are still crap, the still can't seem to get it right after all this time.
    Verbatim DL discs are the best bet. Make sure the DVD drive you buy can bitset DVD DL +R discs to DVD-Rom Booktype, then you can use them and DVD DL -R discs. I would go for the Pioneer 112 drives.
  3. Naqv
    Naqv
    Oct 15, 2006
    3,645
    Birmingham
    +355
    As above, USE DVDSHRINK and DO COMPRESS them. You will not notice the difference between a dual-layers backup disc and a single disc compressed using DVDShrink. I have done hundreds of single disc backups from my dual-layer original discs.
    Just try it, and let me know if you see the difference.
  4. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    if you use dvd shrink and set it to best quality, and remove any extras you don't want (like extra audio tracks for example) you'll get an awesome quality back-up that'll be extremely hard to distinguish from the original :smashin:
    tis good stuff dvd shrink, only thing i use to backup my dvds
  5. bogart99
    bogart99
    Jan 17, 2007
    944
    France
    +62
    Downloaded DVD shrink and got myself a Pioneer DL writer. Been messing about with both. One more question how do I get DVD shrink to write to a DL disc knowing it is such, it always wants to compress everything?
  6. Big_Vern
    Big_Vern
    Jan 10, 2005
    315
    +18
    If you click "Edit" and select "Preferences" you should be able to select DVD9 (8.5GB) from the Target DVD size dropdown.
    Regards
    Big_Vern
