Dual head graphics for HTPC?
Discussion in 'Desktop & Laptop Computers Forum' started by Dodgey, May 9, 2002.
  1. Dodgey
    Dodgey
    Hi, I'm having problems getting my Geforce3 2000Ti on XP working at 856x480. I get 800x600 at 4 bit colour and have to re-install graphics card to revert to normal. Tried latest drivers to no avail. (does it matter that I use an LCD monitor? - wondering whether it is "telling" the graphics card and powerstrip to get knotted?)
    I can get graphics cards free. Was wondering about getting a dual head card of some sort so I don't have to switch lead between monitor and PJ when I get it working. Has anyone done this? i.e. set monitor output to 856 and PJ to 1024 at same time?
    cheers
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i have a geforce2 mx duel head .
    you can set a diferent res for the mon outs . the thing is though that i could only get an overlay on the primary mon . this made the second out usless as a source for my projector
    if only it had worked it would have solved all my problems :(
  3. ajbird
    ajbird
    Apr 30, 2002
    105
    16
    Laceby - NE Lincs
    why not put 2 graphics cards in
    works ok
    andy
