Dual Head Geforce 6600GT
Discussion in 'Desktop & Laptop Computers Forum' started by Atari, Jan 7, 2005.
  1. Atari
    Atari
    Dec 11, 2002
    32
    The Netherlands
    I have a Geforce 6600GT and have both my 17" LCD screen and projector (AE300) connected to it. Both with a VGA connection (one is through DVI-VGA converter).
    I was wondering if one output is better than the other or are both the same quality. Should the projector be connected to one or the other for timing issues (seem to remember something about internal and external TDMS).
    many thanks
    Andrew
  2. Atari
    Atari
    Dec 11, 2002
    32
    The Netherlands
    Silly me after seeing the spec below from the Nvidia website both outputs should be exaclty the same for VGA. Trouble with this hobby is that you always want to push that little bit further , and my wife still thinks it looks the same after hours of tweaking :laugh:
    Advanced Video and Display Functionality
    Dedicated on-chip video processor
    MPEG video encode and decode
    WMV9 decode acceleration
    Advanced adaptive de-interlacing
    High-quality video scaling and filtering
    DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
    Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
    Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
    Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
    Full NVIDIA® nView™ multi-display technology capability
    Advanced Display Functionality
    Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
    Have a good weekend all
    Andrew
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I did post a reply suggesting the VGA output in the DVI-I was the same, but deleted it in case there was something I didn't know. :)
