Dual Firmware? Is it possible?
Discussion in 'PS Vita Forum' started by Twon, Sep 15, 2007.
Tags:
  1. Twon
    Twon
    Mar 30, 2006
    1,631
    48
    +90
    I've got me a PS3 :thumbsup:
    And I'm contimplating spending another £130 I don't have on a PSPlite.:D
    BUT
    I like the idea of running homebrew software while still keeping the functionality of the PS3/PSP link up abilities.
    Is it possible to run 2 firmware at the same time, or is it easy enough downgrade to run custom fw and then upgrade when you want to connect to the good old PS3?
    Or should I just get a cheapy 2nd hand original from the for sale forum and run this with custom fw and get a psplite for my PS3 lovin?
    Thanks,
    Wiltsteve
  2. skinnyfat
    skinnyfat
    The custom firmwares (I'm on DAX 3.40 OE) provide that functionality you are looking for.
  3. Twon
    Twon
    Mar 30, 2006
    1,631
    48
    +90
    Does anyone know if the Custom FW's work on the new boy?
  4. ZebraheadDude
    ZebraheadDude
    Feb 27, 2006
    1,273
    48
    +47
    They do not mate.
  5. WelshBluebird
    WelshBluebird
    Oct 5, 2005
    2,511
    Rhondda
    +135
  6. skinnyfat
    skinnyfat
    Well not yet anyway :D:D
  7. WelshBluebird
    WelshBluebird
    Oct 5, 2005
    2,511
    Rhondda
    +135
    as posted above - there is CFW available for the slim. Its a lengthy process to get it working, but it does work. (only major difference is that the 3.60 M33 on the slim doesn't have any of the 1.50 kernel, so cannot load homebrew made for 1.50 firmware (so you have to use the versions for 2.00 or higher, if available))
  8. ZebraheadDude
    ZebraheadDude
    Feb 27, 2006
    1,273
    48
    +47
    Which makes it worthless, no?
  9. WelshBluebird
    WelshBluebird
    Oct 5, 2005
    2,511
    Rhondda
    +135
    not really. As I said, you can get quite a lot of homebrew apps that can work on a 2.xx kernel.
    (i hope posting this like is ok, its just to copy and paste, then re format all the colours etc would take too long)
    http://forums.qj.net/showpost.php?p=1784724&postcount=1
    Granted, not everything is working (far from it), but a lot of stuff is.
