Dual DVI Audio Output?
Discussion in 'Computer Components' started by BobbyMac, Aug 17, 2013.
  1. BobbyMac
    BobbyMac
    Aug 26, 2011
    6,326
    +1,131
    Looking at buying a 1440p in the classifieds (Crossover q27 led-p), however it only has a Dual DVi output for 1440p resolution
    My graphics card is gigabyte windforce 7950 whch features Dual-link DVI-I / HDMI / Mini DisplayPort*2
    I want to use the HDMI output to send video/audio to my AV Receiver & TV downstairs and use the Dual-link DVI-I to send video to the Crossover monitor at full 1440p resolution
    How would I send audio to my Yamaha YSP-1100 when using the monitor?
    If it helps I also have a Creative SoundBlaster X-Fi Xtreme 7 with optical out if that helps?
  2. cokker
    cokker
    Apr 30, 2008
    918
    46
    Norwich
    +118
    If I have this right:
    7950 HDMI > AV > TV (1080p?).
    7950 DVI-I > 1440p Monitor with optical or analogue via RCA connector?
    That should be fine but you will have the trouble of two audio devices (X-Fi Xtreme and AMD Digital out HDMI).
    Some programs can be configured to use a dedicated audio device, others tend to use the default audio device in windows, depending on the monitor you may have to set this manually every time.
    You can use a program called Virtual audio cable but is not free and can be hard to set up.
  3. BobbyMac
    BobbyMac
    Aug 26, 2011
    6,326
    +1,131
    Yep that's the setup, will mainly use AV setup for XBMC (and the odd gaming sesh)
    Monitor setup is mainly for web browsing and hardcore gaming:smashin:
