D
durad
hi,i have a regular crt monitor(lg f700p) and i use a resolution of 1024X768 @85hz,this is the monitor that i have been using for some years now,and i intend to keep using it as my main monitor..recently i bought a samsung hdtv le26r72b that has support for pc monitor(with vga connection) with a resolution of 1360X768 @60hz so i connected the tv to the vga plug on my gfc and my lg with an vga-dvi adapter to the dvi plug...and my intention is to use both monitors for everything,browser,gaming,messenger,progs..everyth ing,so i need a clone setting that shows me the exact same windows in both monitors..i allready tried everything that my drivers (nvidia 84.26) allows me to,and i did managed to set the right resolutions for each monitor,but big problem,my lg monitor(main for me but secondary for the pc,or else i couldnt set a bigger res for the samsung tv) despite of having the right res does not show the entire screen,i need to scroll it,it is realy bad,because its like if i had a 1360X768 resolution and only part of it was showned,and i have to go with the mouse left and right for everything...in the other hand the tv is ok..so is there any way that i can have a resolution for each monitor,and everything showing up in both monitors?is there any prog or any other way?thanks a lot for your patience and sory for the bad english
