mjn said:If you use the 120gb drive for the OS, say a 50 / 70 split, and format the 50gb (win98SE), partition as FAT32, i don't understand why you'll need to format the 70gb partition (XP) as FAT32 aswell, as some people are suggesting? I'd format the 70gb as NTFS as Win98 does not need to access any files on this partiton.
uridium said:Then again I wouldn't be installing Win98 either![]()
Out of interest why do you need a Win98 partition?
satinder said:I can see that you might have some problems with using SATA drives though as i dont think they were around in 1998 so they might not be recognised by '98. Though i might just be talking rubbish. The second being is that if your son needs to access the files on the xp partition from '98 then the xp partition will need to be formatted as fat32 also.
And the most important point is to back up all the data from your current computer setup onto completely separate drives first, dont forget that especially if you reformat your drives.
Sat
Out of interest what are the games? And don't the run on compatibility mode?T0rNaDo said:he has a few games that he misses playing.
they are old and dont work on 2000/xp
so the 98se he would only use for these few games....
other then that, all the other games and normal running would be on xp
T0rNaDo said:i would of thought. a fat32 partition for 98se and ntfs for the xp partition.
but if i use the 120gb hdd and partition into 2. 1 for 98se and other for xp.
when booted into 98se is it going to see the 2nd hdd as its sata ?
i thought. 120 gb hdd as fat32 for 98se and space for things he needs to install.
and 250gb sata as ntfs and partitioned into 2....
JagoPlasma said:if i were you id do it the way i dual boot my OS'
drive 1 = win MCE
drive 2 = win 2k
install your first disk, install operating system on this disk. (MCE)
install second disk, go into bios and set this as boot disk, then install your second OS (Win 2k)
whenever you want to change OS, go into the bios and change boot drive.
This way nomatter which drive you boot from it will always become drive C: and avoid confilicts
after many years in IT, i find this the best and most reliable way of running TWO OS'
Each one doesnt know the other exists and has no reason to access the others HDD, but with either one booted up you can still see the other OS and drag files across.
Simple and safe![]()
JagoPlasma said:its not too hard, but i guess thats because i dont switch OS's very often.
I just find it alot easier to keep it this way as if one OS/Partition gets corrupt, it doesnt take the whole lot down with it, and the big + is it keeps the OS as the C: drive which can cause alot of problems with other programs if the main drive isnt C:.
Its just my personal prefference and hitting F2(pheonix bios) to go into the bios and pressing a couple of arrow keys doesnt take too long, esspecially when your used to doing it![]()
The only problem with Virtual PC is that it doesn't support USB devices, which may or may not be a problem.djhavor said:Try Virtual PC 2004 from Microsoft. It's fairly simple and, best of all, as from a few weeks ago, it's free
