Hi folks,
I'm with O2 at the moment but likely to move to virgin fibre 'til bt infinity reaches my area.
I need a router for two reasons:
A. Change the dns settings as I use unblock.us to access Netflix US and the virgin superhub doesn't allow for this.
B. I have an antenna I'd like to attach to the router to enhance the signal as I've got a 3 storey terraced house so signal is likely to be weak at the extremities.
I would greatly appreciate suggestions to help...I think my best bet is a decent, cheap-ish router, that is dual band and has a detachable antenna....
Thank you
Thank you
