Member 639844
Former Advertiser
Ive done a little playing today, and things are ok but not perfect. The low volume window rattle I heard yesterday wasnt, it was the internal wiring of the forward driver rattling on the bottom driver, so I've fixed that . Next issue is it really needs a bit of running in yet so I know there is better to come. Third issue is the sealed cabinet isnt sealed as tight as it should be. This is partly down to the fact I havent yet stuck the gasket in place, or got any kind of finish on the MDF. Last issue is I dont have my Audyssey mic to properly eq this sub, and its running the eq setting from my own sub. When I turned Audyssey of the sub sounded a little weak, but with it on its not quite right either to my ears.
It does sound well, and both music and films are pretty decent, but I'm finding it hard not to compare it to my sub . Next job tomorrow is to find a few spare minutes to run REW and see what the response is like and see what is really happening.
I'm reasonably happy with how it sounds at the minute, and its certainly better than any of the sealed subs Ive heard for under 1k. It does sound very similar to the MK's its copying which is a cracking result, but Ive convinced myself there is more to be had yet.
I'll post back tomorrow on how I get on
