DTV interference whenever my HTPC is connected
J
jd_1080
I have a Samsung 40M87BDX 1080p screen that i have connected to my HTPC. It connects fine via VGA at 1920 x 1080p x 60hz and i am also trying a DVI to HDMI connection.
If i have the digital tv tuner active on the telly and connect any cables to the PC (whether the PC is on or off (but PSU still on)) i get loads of interference or even the signal disappearing.
I initially thought it was the other TV tuner in my HTPC or the wireless card but it still happens when i remove both.
It looks like some sort of grounding (earth) type issue and i have tried plugging both the TV and PC into different and the same power sockets but neither has any effect.
my graphics card is an ATI radeon x850 with a DVI and VGA and HD component out (and video in).
Has anyone had a similar problem - does this sound like a PC problem or a LCD tv problem. The TV aerial and power plugs are all quite close to each other and the aerial isn't the best insulated. Does anyone think that buying a better TV aerial lead might help?
JD
J
jd_1080
I have found a few posts on other forums discussing a similar issue:
http://www.videohelp.com/forum/archive/t305852.html
http://www.satcure.co.uk/tech/interf.htm
These are mainly talking about using double screened cables and keeping audio/video leads away from power cables.
In my situation it is only a huge problem when the LCD and PC are connected via an HDMI or VGA lead.
Are you all using top quality HDMI leads to connect PC to LCD or would a cheaper one do?
Cheers for any help
JD
⭐ Philips OLED+908 TV preview + REL subwoofer and Avid Accent amplifier reviews + Hi-Fi & AV News
Back
