dts
Discussion in 'AV Receivers & Amplifiers' started by betamax-uk, May 20, 2003.
  1. betamax-uk
    betamax-uk
    i have a denon 1603 av receiver and a jvc dvd what cable do i need for dts to play on my denon im new to this so dont slag off my denon lol. i had a sherwood prior to my denon. any advice would be great
  2. ChrisNic
    ChrisNic
    May 11, 2003
    1,701
    48
    Thame
    +63
    You need a digital coaxial cable from the dvd player to the digital input on your denon. Then when the menu comes up on the Dvd if it has a DTS soundtrack go to audio set up and select it there then your reciever should automatically switch to DTS.
  3. betamax-uk
    betamax-uk
    cheers ty
