Here you go, courtesy of MyMovies;
ANY help to work out why this is not working!Just delivered from Amazon, try later, first time with DTS X.!
Had to check the rear cover to make sure it is there.
Never heard of The Huntsman before , worth a go just to hear the sound difference!
I have the huntsman br disc with DTS X in it.
I use a Panasonic DO BDT460 player into a Denon avr x1200w.
All the display shows is DTS no x.
Is this correct?
Done all updates and settings
Is this correct?
Thanks for help.I have a different AVR, so may be slightly different.
I think you will need to Bitstream from the BR Player to the AVR, with Secondary Audio OFF.
Make sure you select DTS-MA soundtrack in BR Player.
Once the film is playing, see what the AVR sees as incoming Audio Signal. You may need to use the Surround Mode to select DTS - if struggling from here, may best to posts a picture of the Audio INFO from the Denon.
Thanks for help.
I have these settings so far and it does sound better!
Is this correct from the pictures I took
View attachment 751513View attachment 751514
X2 ceiling. X2 rear.x2subs. L+R +centre speakersAs asked on the previous page what speakers system do you have, how many speakers in total, Atmos/in ceiling speakers ?
I been through the whole manual and there is no mention of any displays available on the avr of DTS X or Atmos.Must be a setting in the amp then if you are still not getting Atmos/DTS :X I'm not familiar with the latest Denon amps so cant suggest what settings are wrong ?
It seems Dolby HD +S or DTS HD is all it was manufactured to display so any online upgrades don't seem to be including display updates.
I suppose I will have to accept that it is doing what it meant to by checking all settings.
Does sound very good though!!
As a guess just push the Green Movie Button – it's one of the sound mode buttons on the remote – until it says DTS:X on the front displayI been through the whole manual and there is no mention of any displays available on the avr of DTS X or Atmos.
Thanks Dante.The Reason that you are not getting the DTS:X soundtrack is because you have the receiver set to Dolby Surround for that input. THe receiver will revert to the 7.1 DTS-HD Master Audio base layer and ignore the DTS:X metadata if applying DSU to the audio coming into the receiver. Press and hold down the green MOVIE button on the remote until a meni appears onscreen. Select the discrete incoming audio from this menu as opposed to any of the surround modes. Note the same is true of apply Neiral:X to Atmos audio. You'd not get Atmos and you'd get TrueHD with Neural:X applied to it.
Thanks Dante.
I have tried green button and selected DTS HD MASTER. Also tried all the others but still the display is DTS HD MA .
I have posted on this thread a few back images of BR player and avr settings.
Shame really .I have the Disc. Br player. Avr all ready to do it but no go.
Maybe I have a bad quality hdmi lead?
Thanks Dante.
There is the problem. ! The version is 2400.3140.4001. No DTS .Sorry to check the most basic of things, but go to
SETUP -- GENERAL -- INFORMATION - FIRMWARE -- DTS VERSION
If "DTS Version" is listed, it has defo been installed.
The best info for the Denon is by pressing INFO button on the AVR controller. That should show input and output speakers, along with Surround Mode selected. (Or does on mine). Post a picture of that. It may ne best to post in the X1200 Thread to resolve...
I tried ro update firmware but it says I have latest installed.
I'll have to wait
I still do not have dtsx receiver but wanted to know how good it is compared to dts hd?It is good though isn't it !
I have 5.1.2 with upfiring KEF R50s. Big improvement in the front soundfield, filling the gap between speakers and ceiling. Love it, especially Neural:X.I still do not have dtsx receiver but wanted to know how good it is compared to dts hd?
Do you have a 5.1.2 or 7.1.2?
