dts sound card
Discussion in 'Computer Components' started by buns, May 19, 2001.
  1. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Is there any way that the HTPC can decode all the digital and dts and assorted ex es fromats then send a signal straight to a power amp.....it sounds like something that would be beneficial if it could.....no more upgrading processors, just up the software!
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,735
    7
    2
    167
    Birmingham, UK
    +10,623
    As far as I'm aware, no.
    It would require a specific hardware card to provide the various audio outputs, and I've never heard of such a thing.
    Whereas the 'traditional' home cinema PC uses standard hardware cards (video and sound card).
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
  4. Branxx
    Branxx
    Nov 1, 2000
    810
    London, UK
    PowerDVD has built in AC3 decoding in software (6 speaker option). Using suitable multi channel card such as Delta Dio 1010 or HoonTech AudioDSP24 with external DAC, PowerDVD will output 6 discrete channels which can be fed directly to power amps. However, for everyday practical purposes this is nt very user friendly as yet.
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    nor is it very affordable by the looks of it!
  6. dannyc
    dannyc
    The Midiman Delta 1010 is definitely the way to go, I took the plunge and it sounds way better than my Yamaha DSPE800, it does cost £530 inc VAT though.
    Also you still need a means of volume control before the power amp stage.
  7. polo
    polo
    or just wait for the new win dvd program 3.0 which can play dts :D
