DTS problem for newbie
Discussion in 'AV Receivers & Amplifiers' started by waylander, Jan 31, 2002.
  1. waylander
    waylander
    Jan 31, 2002
    I have recently purchased a yamaha dsp-ax620 which seems to be working fine however when i try to play a dts encoded dvd through it i get no sound reproduction, am i doing something wrong, please help
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,872
    2
    In a secret location with Jennifer Lawrence
    +10,926
    Not sure what you have tried yet, but have you told the DVD player to output the DTS signal? Most DVDs that have DTS and Dolby Digital will play DD by default.
    Greg
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Make sure the Amp is set to auto. It only takes one slip of a button to set it to analogue only. This would mean you might be hearing dolby prologic surround instead of DD, and you wouldn't hear a thing with DTS. Also make sure the digital input the DVD is plugged into is correctly assigned to the DVD.
    Apart from Greg's suggestion, that's all I can think of at the mo.
  4. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,951
    make sure you select DTS soundtrack in audio menu of film.
