DTS Out
Discussion in 'Blu-ray & DVD Players & Recorders' started by gtfc, Jan 19, 2002.
  1. gtfc
    gtfc
    I can't get my Sony NS300 to output a DTS Signal from JP3 to my amp (acording to box it has it ), the legend in the display stays in DD mode.
    Anyone seen this before.
    Many Thanks
    John
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    What amp do you have? Without being patronising, have you selected DTS from the JP3 audio setup menu?
  3. Doubledoom
    Doubledoom
    and, in addition to that, have you turned DTS on in the dvd menu. Usually DTS is turned off as default
  4. Guest
    I thought that most DVD players have the electronics on board to process the audio stream that it was presented with. So if you give it AC3, it will output a bitstream which a Dolby Digital decoder can process. If your disc has a DTS audio stream, it will output it and you have to buy an expensive DTS decoder to hear it. Maybe JP3 is AC3 and the DVD thinks it's AC3??
  5. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Yep. My DVD player doesn't distinguish between DD and DTS, just asks for a digital out to be turned on, and lets the amp do the work. Not being familiar with your player, maybe it needs to be set to output DTS? Unless 'Doom is on about the JP3 DVD menu, in which case I already covered that.
  6. gtfc
    gtfc
    Hi all ,
    Thanks for the replies.
    I'ts a Kenwood KRVX 9050, The Sony Audio menu is set up with Digital output ON, DD On and DTS ON. via a Digital Coax.
    You don't seem to be able to deselect DD and leave DTS on so I assume either format sends out an identifying signal to the player and RX.
    MY DD mode light is lit on the receiver together with THX.
    As the actual disc is a Rental one could that be minus DTS which is only present on a full retail double disc version.
    There is no Audio setup menu I can see on the Intro.
    Regards
    John
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    That's bad news then though call up the menu and check under "Language Selection". Or play the movie and try to toggle the soundtrack using the 'Audio' button on your remote.
  8. Doubledoom
    Doubledoom
    My DVD player has an option in the audio menu that turns on/off the passing of the DTS signal to an amp.
    If its off and you select the DTS soundtrack, you get no sound.
