DTS or DolbyDigital? Poll
Discussion in 'Blu-ray & DVD Players & Recorders' started by phillips321, Dec 21, 2004.
  1. DTS
    76 vote(s)
    85.4%
  2. DolbyDigital 5.1
    13 vote(s)
    14.6%
  1. phillips321
    phillips321
    Hi guys.
    Im new to the home cinema scene but im confused as to which surround mode i should be using. My set up is
    Crystal DiVX player
    Yamaha A5
    Eltax Concept (front) (all bass routed through these)
    Eagle (rear)
    Sony (centre)
    Most of the DVDs i have give me a choice of either DolbyDigital 5.1 or DTS, which shouldi choose? What are the differences between them?
    Can any one also point me in a direction that directly compares them both?
    Cheers guys
  2. Family Guy
    Family Guy
    Pertsonally mate, i would just carry out a search using the search facility...or put your flamesuit on and prepare to run, you just don't know what you have started...
    Mind you, the monthly DD vs DTS debate seem to be petereing out just lately, maybe this will rekindle the flame.... :devil:
  3. Family Guy
    Family Guy
    This should get you going... :thumbsup:
  4. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    Can I ask a dumb question?...
    What's the difference?
  5. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    This debate is always going on. I find that on most dvd's available in dts you have to actually manually change it in the audio options menu. So if it's not the best option why is it not default sound when you stick the disk in???
  6. pob
    pob
    Mar 28, 2002
    1,628
    Sheffield, UK
    +157
    DTS is not the default soundtrack as it is ONLY compatible with DTS decoders. Those people that have their DVD player sound connected to a TV or a non-DTS amp will get no sound at all.
    Phil
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,822
    London
    +1,091
    I normally use DTS if given the choice!
  8. mattrixdesign
    mattrixdesign
    If there is a DTS option I use it, I am not even sure why! I think its time spent on this forum has convinced me DTS is better. I don't think I could tell the difference in a blind test :blush:
    One thing I have noticed is that DTS seems to have more bass and is louder, may be thats just my system. Any well mastered 5.1 track sounds good Dolby or DTS, but there are many dodgy ones out there - I have a lot of older films that state 5.1 on the package, but they rarely make use of the full surround - which isn't suprising considering the source material is analogue stereo.
  9. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    The poll speaks for itself :D
    (bloody Dolby fan boys! :rolleyes: )
  10. Kier
    Kier
    Nov 21, 2004
    Reading, UK
    +3
    In my experience, DTS is louder but Dolby Digital is more refined and has a smoother transition between very low frequency bass and more 'mainstream' bass, resulting in a more pleasing soundtrack...
    ... to my ears anyway.
    Ignore the DTS claims that their system uses a higher bitrate than Dolby Digital - this does not take into account the fact that the compression algorithm used by Dolby Digital is quite a bit more sophisticated and so more information can be packed into a lower bitrate than with DTS.
  11. Supra
    Supra
    Dec 12, 2002
    433
    Kent
    +14
    Always use DTS if it is available
  12. mattrixdesign
    mattrixdesign
    Hmmm. Poll suggests DTS is the prefered choice, I am not suprised, I even chose DTS, but as I said before I am not sure why.., I would like to see what people prefer in a blind test!!!
  13. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
  14. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Different encoding technologies. As to actual difference (ie when listening) that is the subject of much debate :D. Hence this thread, and many others like it.
  15. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    I see the point you are making but (and isn't there always a but) I honestly think that you can't really compare DD and DTS, DTS is streets ahead!!
    Cheers,
    Martin.
  16. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    DTS uses much less compression and hence more of the original soundtrack is retained.
    Cheers,
    Martin.
  17. Family Guy
    Family Guy
    Can you post some scientific proof of this? or is it just your opinion...?
  18. Family Guy
    Family Guy
    Crap...Read this thread (including the links - in fact espicially the links) to find out why that is a myth...DTS may have a highe bandwith, but Dolby Digital is a less lossy format, which means that more of the original track remanins in the encryption.
  19. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    Technically speaking DTS should be ahead of DD with all that bandwidth available, higher sampling rate, wider frequency band etc. but in real terms it's not. There are instances where DD sounds better than DTS and visa-versa, but most of these are down to the mixing rather than the technology.
    There are instances where DD can't compete, and if you want a discrete rear channel for 6.1 then DTS is the only format to support it (LOTR extended editions are a fine example). But all the raw facts and figures in the world can't compete with the fact that if the guy mastering the audio happens to be having a good day when he does the DD/DTS transfer, that'll be the winner.
    I don't understand why people get so hung up on it. Personally I find that DTS sounds better, but I think it's more to do with the fact that it's added after the main soundtrack get's mixed and hence get's some special attention.
    At the end of the day, isn't it just nice to have a choice?
  20. Benfica
    Benfica
    Just for curiosity, can you provide me the name of a DVD title that has both DD and DTS where DD is better then DTS ?
    Best regards
  21. Family Guy
    Family Guy
    No - but I could list all day the dics where ther are no or very minimal differences...
    I never said that DD was better than DTS...I'm just of the opinion that it's not THAT MUCH better...not enough to waste valuable bulb on my PJ going through the menu's to select a soundtrack that isn't any better than the one I would by pressing "PLAY"...
    There are however, instances, where there are extended mixes of the Doby version on a disc where the DTS version is un extended...Atlantis being one...Peter Pan being another.
  22. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    Zzzz.....
  23. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    DTS or Dolby?
    Couldn't care less as long as it makes the walls shake at reference level :D
  24. Ovation
    Ovation
    I've been choosing DTS lately (where I can) but that's largely because I haven't had DTS capability for very long (previous AVR only had Dolby Digital). Can't say that I've noticed a huge difference, except some bass that seems a bit louder. Visuals distract enough from critical listening to minimize the differences anyway.
  25. Benfica
    Benfica
    Honestly i think both are as good ... as who makes them want them to be good.
    Unfortunately, there are some cases where DD or DTS tracks do not have the quality that should be required in a commercial DVD (at least in my opinion). After all we still pay a considerable amount for an original DVD and sometimes what we get is crap (audio concerned, for what matters). But we only find that after buying it !
