DTS or 5.1 ?
Discussion in 'AV Receivers & Amplifiers' started by iMan, Dec 30, 2004.
  1. iMan
    iMan
    Mar 30, 2003
    34
    DTS or 5.1 What's the difference and which is the best quality?
  2. Midge
    Midge
    Oct 2, 2002
    312
    Bristol
    +6
    No idea what the difference is, but when watching movies I prefer DTS as it always seems to have more 'kick' to it.
  3. whats_this
    whats_this
    Dec 26, 2003
    484
    +8
  4. boab_is
    boab_is
    oh god not this debate again........... :laugh:
    a recent poll on a certain other set of forums DTS got 2/3 of the vote.
    its personal preference, i tend to find DTS has a better balance (no turning the amp up and down throughout the movie). also seems to give a more musical sound.
    let your ears be the judge......
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,501
    London
    +995
    I assume you are asking the difference between DTS and Dolby Digital.
    5.1 refers to a typical home cinema setup i.e. 2 front stereo speakers; a centre speaker & 2 rear speakers. The .1 refers to the LFC (low frequency channel) i.e. the subwoofer. you get 5.1 DTS & 5.1 DD.
    I believe that DTS uses lower compression rates which gives a more detailed sound. I always find that DTS sounds 'louder' than DTS. As to which is 'better' comes down to personal choice.
  6. iMan
    iMan
    Mar 30, 2003
    34
    Thanks, that's clear now.
  7. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    How does AC-3 come into the picture?
  8. richgtfc
    richgtfc
    Feb 14, 2003
    129
    19
    Edinburgh
    That's the old name for Dolby Digital
    Rich
  9. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    Or more specifically, AC-3 is the name of the audio compression technology used in Dolby Digital. :)
    I wonder how many of the supposed audible differences between the systems comes down to differences in approach though? They may not even play back at the same respective levels in a setup.
    Dolby Digital uses dialog normalization, which adjusts the playback volume so that any two movies should play back dialog at the same level. It also usually phase shifts the surround channels 90°, so that DVD players can directly create a Dolby Surround-compatible 2-channel stereo downmix. Furthermore, the bass management used in production is supposed to differ a bit between the two systems, so it may match or mismatch flaws in a playback system, making them sound different.
    Dolby Digital EX also uses a 45° phase shift to the left and right surround channels in opposite directions before encoding the back surround channel. I don't know if DTS-ES Matrix does that and what matrix decoder they use, if it's the decoder they designed for DTS Stereo, a deriviate of Neo:6, or a licensed decoder from someone else. DTS are a lot more hush-hush about their technology than Dolby.
    So, they may behave differently from one another during production and playback for reasons other than performance.
    And on top of that, the Dolby Digital and DTS soundtracks may not necessarily carry the exact same mix, but differently tweaked versions of it or maybe even two different mixes of the soundtrack.
  10. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I have a Toshiba SD-330E and Pioneer VSA-EO3 amp. They are optically connected. When I select DTS, I get no sound at all. What could the problem be? There is a bitstream/PCM option, is it something to do with that?
  11. Mandel
    Mandel
    DTS is generally accepted to be better quality than Dolby Digital. However a lot of films do two different sound mixes for DTS and Dolby, with the DTS being a bit more 'gratuitous' and designed for people with good sound systems.
    Also DTS-ES can be encoded as discrete 6.1 rather than DD-EX which can only be 5.1 matrixed to 6.1 :)
  12. Family Guy
    Family Guy
    :rotfl:
  13. Barend
    Barend
    Apr 12, 2004
    804
    +9
    For movies, both Dolby and DTS are OK afai'm concerned.
    For music (or movies with an important music score) I prefer DTS as it is a bit more transparent and tends to leave the fronts intact.
    Barend
  14. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Does the VSA E03 say it will decode DTS? If it doesnt your gonna get silence.
  15. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    Dunno. My Brother in Law reckons it does but I'm not so sure.
  16. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    You should see a DTS logo on the front of the amp (normally alongside the dolby digital logo) if it does. If not, then I'm afraid you can't use the DTS soundtracks.
  17. Family Guy
    Family Guy
    This (I have no idea what language it's in...) dosen't show a dts logo on the front, so probably dosen't decode dts.
    Looks like it's from the era of my old VSA E06, which was THX Ultra certified but didn't decode dts.
    IMO, you're not missing much anyway...and well set up amp will sound good in DD or dts, regardless of whether it's an high end system or not...contrary to some posts here... :rolleyes:
  18. Mandel
    Mandel
    My point was more that if you are trying to listen at quieter volumes and don't want a large dynamic range you are sometimes better sticking to the DD track. :rolleyes:
  19. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    The amp has a "midnight" function for listening at low levels.
    My whole system is compromised at the mo anyway, as I'm living in a small bungalow that I'm goiing to re-build soon so I won't loose any sleep until I can "design my own" room
