DTS on Sonys 940
Discussion in 'AV Receivers & Amplifiers' started by johna, Dec 15, 2000.
Tags:
  1. johna
    johna
    Dec 15, 2000
    874
    Kent
    +4
    If your using a dvd player without dts decoding connected to sonys strb940 via optical - should it play???
    help
    john
  2. Guest
    yes, it should
    but,
    1) Does the player support DTS (some don't)
    2) have you enabled DTS out on the player.
    Are you getting Dolby Digital tracks properly ?
    3) I seem to remember that my Sony 930 had a setting (button ?) which set the DVD option to accept only digital connections. You could have a look in your manual to see ????
  3. Guest
    Assuming you mean a DVD player without an internal 5.1 dts decoder, then yes, it should play assuming it isn't a 'first generation' deck.....however most DVD players must have the dts digital output enabled via the audio setup menu of the player itself.
    [This message has been edited by PeteH (edited 15-12-2000).]
