DTS on Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by Tweeter, Dec 27, 2001.
Tags:
  1. Tweeter
    Tweeter
    Can anyone help? or am I being stupid!
    I have just bought and set up a Denon 3802. This replaces my ageing Yamaha DSP-A2070. So this is my first experience of dts.
    I have connected up my Kenwood DVF-5020 DVD player with every connection available (5.1 ext output. optical and coaxial digital). I have tried playing both Rush Hour 2 and the Return of the Mummy both of which are marked 'dts' but the 3802's dts indicator does not light up.
    Ive tried seting the digital output on the DVD player to both PCM and bitstream, still no joy.
    HELP!!
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Have you set the Denon´s input mode to AUTO ??
    If not, try it.
    The dvd output should be set to Bitstream.
    Also make sure in the setup menu you have the Digital In Assignment set correctly.
    cheers
  3. Tweeter
    Tweeter
    Thanks for your reply Jase,
    Unfortunatley I have tried all you have suggested with no result. In auto mode the Dolby Digital indicater comes on but still no dts. I have tried both optical and coaxial digital inputs on the Denon 3802. The sound using the six analogue outputs from the DVD to the 3802's EXT. input is great, but I would like to try the dts ES with the seven speaker set up.
    Its probably something silly but I can't see what.
    Tweeter
  4. mjn
    mjn
    May 24, 2001
    23,230
    Herts, England
    +11,483
    have you enabled "dts out" on your dvd player in the setup menu?? As you can enable/disable this option in many players.
    Are you selecting the DTS soundtrack in the setup menu of your film?? Default soundtrack is usually Dolby digital.
  5. Tweeter
    Tweeter
    Many thanks mjn
    I new I was over looking something, just couldn't figure out what.
    You were right all I needed to do was to select dts in the disc menu.
    Again many thanks
  6. Tweeter
    Tweeter
    Many thanks mjn
    Again many thanks
  7. mjn
    mjn
    May 24, 2001
    23,230
    Herts, England
    +11,483
    no problem :)
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    BTW: you do not need the 5.1 connection if you use coaxial or optical (again only one is required).
