DTS on a Denon 2803
Discussion in 'AV Receivers & Amplifiers' started by jjcarteruk, Dec 17, 2003.
Tags:
  1. jjcarteruk
    jjcarteruk
    Hi all!
    I just bought a Denon 2803 and have a DVD that claims to be in both DTS AND Dolby Digital, but I don't seem to be able to hear anything when I switch (manually) to DTS on the Denon.
    Does anyone know the solution here or have a similar problem?
    Thanks.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Have you set the DVD players digital output to "Bitstream"?
    Also, dts isn't automatically output by the DVD player. You'll have to go through the DVD's menus (usually the language menu) and manually select it.
    You can leave the receiver set to "Auto".
  3. SanPedro
    SanPedro
    Jan 11, 2001
    4,501
    +504
    Assuming the movie actually has a DTS track.
    If I'm not mistaken all DVDs (well new ones anyway) have a DD 5.1 track but not that many have a DTS track.
    Chris
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Good point. EVERY DVD has a DD track (not necessarily 5.1, it could be 1.0, 2.0, 4.0, 5.1 amongst others) as it is part of the DVD standard.
    Only a few (increasingly common in new releases, and many more abroad) have DTS.
    However, since the DVD mentioned in the original question apparently does have DTS, it shouldn't be a problem.
  5. jjcarteruk
    jjcarteruk
    Thanks guys.
    Eviljohn2, you're dead right... just hadn't thought of looking on the language menu - not perhaps the most intuitive place to put the DTS option. Everything works fine now, so will look forward to comparing the two sound formats. (Film is "Pirates of the Caribbean". R2, but it does have a DTS soundtrack in addition to DD)
