DTS Neo:6 V Pro logic II
Discussion in 'AV Receivers & Amplifiers' started by JT, May 6, 2001.
  1. JT
    JT
    Jul 18, 2000
    141
    +4
    I know most people have not heard PLII but the question is the DTS neo:6 the same type of thing? and is it any good? Also does the neo 6 work with 5.1 speakers?
    thanks JT
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,683
    Bob T briefly describes it in his review of the Denon AVC-A1SE on this site.
  3. Matty N
    Matty N
    It is a more "ruff n ready" form of PLII. I believe it will still work well if you have a standard 5 speaker setup, plus sub.
    Do a search of the BBS to see what other users think. Personally I reckon that until I have DPLII, it is usually my choice for decoding DPL encoded material (although the effects can be a little random at times).
    Matt
