DTS Lip Sync Problem: Player, Amp or Disk
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Jun 17, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,186
    Born in Bristol but now in Newport, (for my sins)
    +733
    I am currently using a Samsung 709 and Sony STRDB-930.
    I have just watched Castaway in DTS, and again, the DTS sound track is slightly out of step with the video.
    However, the DD track is fine.
    This is the same on ALL of the DTS disks I have (i.e Gladiator, U-571 etc)..
    I therefore don't think that its the disks which are at fault, which means that its either the DVD player or the Amp...
    Does anyone else get this problem?
    Any idea whats causing it?
  2. Guest
    It's a firmware issue on the samsung, common(ish) with other players of that generation.
  3. bigalroz
    bigalroz
    Nov 21, 2000
    53
    Stirling,Scotland
    I have the Samsung too but don't get this check you have the latest firmware version.
  4. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,186
    +733
    Got firmware 3.32.. Can't get any higher than that...
    When DTS first came out, I found a problem with DTS disks.. If you fast forward/rewind them when playing DTS, the picture goes 'low resolution' and stays this way when you continue to play.
    If you do pause/play it goes back to normal.
    This was reported to Samsung and they said that it was under investigation.
    I recently spoke to an engineer at Samsung about this and was told that it was a HARDWARE problem... Not software.
    Its possible that a batch of Samsung players have this 'hardware' problem when playing DTS.. As such, perhaps these same players have the lip-sync problem too.
    I am worried, as I want to upgrade my DVD player and want to be sure that the model that I get doesn't have this problem too.
