DTS Help Needed!
Discussion in 'AV Receivers & Amplifiers' started by Jay2000, Jan 4, 2001.
  1. Jay2000
    Jay2000
    I'm finally in a position to set up my first surround system after getting by on a 2 channel set-up.
    I want to buy a DTS amp but I'm on quite a tight budget.
    I've been browsing through the Richer Sounds website and seen something that has totally confused me. They have a Kenwood KRFV5030 amp that is only Dolby Digital (not DTS) BUT they also state in the specs that it has '6 channel output for DTS'.
    I was always under the impression that the amp had to have a DTS decoder on board to deliver a DTS output. Am I missing something here or just being dumb?
    I have an LG 3350E DVD player with on-board 5.1 outs. Can I get DTS from this amp or not? Help!
    Jay
  2. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    They mean 6 channel input for an external DTS decoder.
  3. Paul D
    Paul D
    Dec 27, 2000
    2,733
    Manchester
    +533
    What they mean is if your DVD player has DTS out on its phonos (ie onboard DTS decoder). You can connect them to the 6 channel input on the amp hence DTS output!. Its a bit of a con by Kenwwood because they did't provide onboard decoding. Or as the answer above states you can use a seperate DTS decoder but on a budget this is not a cheap option. Hope this helps. Paul
    I'am not drinking anymore....but i'am not drinking any less
  4. Mad Max
    Mad Max
    So, basically, if you want DTS, don't buy that receiver !!!
    Because you're on a budget, you need to get a DTS receiver, since DVD players with On-board DTS decoding tend to be more expensive than the ones without. Most players have DTS-out, which means they can send the DTS bitstream to the Amp for decoding. Therefore I think you're better off buying a cheaper player, and a little more expensive receiver.
    Regards
    An adult is just a kid with expensive toys.
    Rui
  5. Jay2000
    Jay2000
    Thanks for your help guys - I knew there must have been a catch somewhere... [​IMG]
