DTS-HD MKV file, how to get the full sound??
chavo
Hi.
Ok here is the situation,
onkyo 607 amp
HTPC windows 7(32 bit) with ATI 5450
7.1 speakers.
Shark 007 codecs
TMT3
PDVD10
VLC
I have a MKV thatis supposed to be 7.1 DTS HD. when i try to play it in pdvd or tmt3 it freezes and i get nothing. when i play it on VLC i get playback but only in DTS core. I have managed to get a full rip to work on TMT3 with DTS-HD so i know that isnt the issue. it is definetly a configuration problem between the mkv and the codecs.
Anyone else have a similar issue that they fixed?
chavo
Thanks i will have a look at these. i have read that all MKVs with dts hd have difficulty playing back stutter free. i will remove shark tonight and i will give that tutorial a go.
leon
have you tried zoom player i find it amazing for hd and you can select all the pass through formats for your amp.
chavo
good call wih Zoomm aate. its a bit stuttering but sure i will fix that, straight to DTS HD! tried to follow that guide but still couldnt get it to work!
leon
if you go into advanced options and enable smart play . in there you an choose your sound card and how you want to output it to your amp:smashin:
