Question DTS-HD MA 7.1 on VERO 4K 100% processors and jerky picture
Stone28
HI All,
I have a file 1080p DTS-HD MA 7.1 x264.mkv. The sound plays OK but the video is really jerky. I thought VERO 4K can handle everything and I am hoping it’s just some of my default settings on it are wrong. It’s connected via HDMI to my Pioneer amp which can handle DTS-HD and I have sound set on Vero as passthrough. However it still shows on my amp as PCM and not DTS-HD. Also while playing all processor cores on the Vero go to 98%-100% so clearly it’s struggling.
I had another file with DTS-HD MA 7.1 and it plays OK. That’s the only file which is almost unwatchable.
Also it must be something with settings but recently all files (no matter what audio TrueHD, DTS, DTS-HD they all show on amp as PCM!
Is it possible that something is wrong with Vero itself? I lost front blue led light as well recently (the one that shows the Vero is on) so maybe something is wrong.
Thanks,
-= MEDIA INFO FILE =-
General
Unique ID : 208758552487636399468967154282562259252 (0x9D0D6F4B022674CC030EBD75714F0934)
Complete name : I:\Filmy!Nowe 2018\The Greatest Showman 2017 BluRay 1080p DTS-HD MA 7.1 x264-LEGi0N\The Greatest Showman 2017 BluRay 1080p DTS-HD MA 7.1 x264-LEGi0N.mkv
Format : Matroska
Format version : Version 4
File size : 14.4 GiB
Duration : 1 h 44 min
Overall bit rate mode : Variable
Overall bit rate : 19.7 Mb/s
Encoded date : UTC 2018-04-10 18:44:43
Writing application : mkvmerge v22.0.0 (‘At The End Of The World’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High [email protected]
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 13.5 Mb/s
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.367
Stream size : 9.89 GiB (69%)
Writing library : x264 core 155 r2901 7d0ff22
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.90:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=22 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=crf / mbtree=1 / crf=13.0 / qcomp=0.60 / qpmin=0 / qpmax=59 / qpstep=4 / vbv_maxrate=38000 / vbv_bufsize=38000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.30 / aq=1:0.90
Language : English
Default : Yes
Forced : Yes
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : DTS ES XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 5 243 kb/s
Channel(s) : 8 channels
Channel layout : C L R Ls Rs LFE Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.84 GiB (27%)
Title : English DTS-HD MA 7.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 336 MiB (2%)
Title : English Descriptive AC3 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 224 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 168 MiB (1%)
Title : English Directors Commentary AC3 2.0
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 43 min
Bit rate : 167 kb/s
Count of elements : 5255
Stream size : 124 MiB (1%)
Title : English Sing Along Lyrics .sup
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Bit rate : 51.5 kb/s
Count of elements : 3728
Stream size : 38.1 MiB (0%)
Title : English SDH .sup
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Duration : 1 h 36 min
Bit rate : 54.2 kb/s
Count of elements : 2359
Stream size : 37.5 MiB (0%)
Title : English Directors Commentary .sup
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:1
00:03:21.618 : en:2
00:11:33.985 : en:3
00:16:21.314 : en:4
00:21:13.731 : en:5
00:25:04.169 : en:6
00:32:10.178 : en:7
00:36:09.626 : en:8
00:41:38.413 : en:9
00:44:41.053 : en:10
00:48:24.151 : en:11
00:53:11.146 : en:12
00:56:20.711 : en:13
01:01:34.816 : en:14
01:07:33.883 : en:15
01:12:00.983 : en:16
01:18:23.699 : en:17
01:22:07.131 : en:18
01:29:04.798 : en:19
01:37:09.449 : en:20
next010
OSMC forums might be able to help better especially if their is a hardware fault but as OSMC is derived from Kodi the audio settings in kodi typically function like this.
Multi-channel PCM audio output
Number of channels = 5.1 or 7.1
Pass-through = disabled
Bit-streaming
Pass-through = enabled
Tick the boxes for what formats your receiver supports. I think this also needs the settings level set to expert.
There's no difference in audio quality PCM is the same audio you just don't get the logo lights on your receiver.
They do offer a reinstall and restore method. The jerky video could be a hardware fault or a failure in the software to properly hand off to the hardware video decoder. Ask over on the OSMC forums and post the diagnostic logs (see here on how to grab them) that will let the devs know exactly whats going wrong.
