DTS from Denon 3801 & Pioneer 626
Discussion in 'AV Receivers & Amplifiers' started by PaulBoy, Jan 29, 2001.
Tags:
  1. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    My recent 3801 upgrade was to replace a DPL only Yamaha A592 - To get DD & DTS from the Yamaha I paired it with a Pioneer 626D DVD player which has its own on board DD & DTS decoders - My question is when I listen to a DTS DVD how can I tell if I have set the 3801 / 626 up correctly so that the DTS is being decoded by the amp and not the DVD player ?
    TIA - Paul
    "Hi my names Paul and I'm a dvdaholic ..."
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    If it is only connected via coax or Toslink then it must be the amp.
  3. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    Jeff - Thanks - Why didnt I think of that ?
    It is connected by co-ax [​IMG]
    [This message has been edited by PaulBoy (edited 29-01-2001).]
