DTS-ES on AVR300
Discussion in 'AV Receivers & Amplifiers' started by raymci, Aug 25, 2004.
Tags:
  1. raymci
    raymci
    Aug 24, 2004
    29
    3
    +3
    Is there any reason why my AVR300 cannot play the DTS-ES Discrete soundtrack of a DVD when configured with only 5-speakers (front/center/rear) i.e. no Surround-Back speakers? I only hear a faint noise from the speakers.
    I previously posted this under the v2.84 software update thread, but this is annoying me a bit now... shouldn't the AVR300 play the DTS-compatible portion from the DTS-ES Discrete sound track when only configured with 5 speakers?
    At the moment, I can only play the DTS-ES soundtrack if I enable the SurrBack speakers in the menu (even if I don't actually have any installed/connected)... is this a limitation of other amps as well??
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    This is, I believe, a bug. I am able to duplicate the problem on my AVR300 (I normally do have a 7.1 setup) by disabling the rear surrounds and playing the Stargate Ultimate Edition DVD (DTS ES 6.1).
    I've also reported this problem to Arcam (in case they aren't aware of it yet).
    Dean
  3. raymci
    raymci
    Aug 24, 2004
    29
    3
    +3
    That's good to know... thanks for checking this out Dean. Hopefully we'll see this fixed in the next software update... :)
  4. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Arcam acknowledged my problem report. Although I can't speak for them, my experience tells me a fix would be likely in the next release.
    Dean
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Arcam has fixed this problem with software update v2.90. Just saw it posted on Audiophile System website.
    Dean
  6. raymci
    raymci
    Aug 24, 2004
    29
    3
    +3
    Hi Dean,
    I saw that, and have upgraded to the v2.90 software. The DTS-ES films now play correctly now (shown only as DTS on the panel), so you obviously need to have the 7.1 speakers configured before getting true DTS-ES Discrete playback... which is fine! :thumbsup:
    Top job by Arcam to get the fix in so quick.
    Ray
  7. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Right, because DTS ES is a 6 channel format.
    Arcam has been really good about software issues quickly.
  8. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    ES-Discrete flagged material should get decoded if you have 6.1 or 7.1 system. In the case of a 7.1 system the discrete SB is copied to SBL, SBR and level is reduced by 3dB as you have two speakers reproducing the same signal. Same applies to ES-Matrix flagged material, when the disc is flagged as ES-Matrix and ES-Discrete encoded then ES-Discrete has priority.
    If it shows as only DTS then that hints that the extensions are not getting decoded, so you'll get the baseline 5.1 DTS decode, or you have a 5.1 system in the place.
