Dts es matrix with Denon 3805
Discussion in 'AV Receivers & Amplifiers' started by Pacha, Feb 24, 2005.
Tags:
  1. Pacha
    Pacha
    Oct 29, 2002
    134
    Just upgraded from Denon 2802 receiver to the 3805.
    On the 2802 when i listened to a standard DTS (i.e. 5.1) soundtrack the display would tell me that it was decoding 'DTS es matrix' (this was with the auto flag mode switched off and matrix processing switched on.
    On the 3805 i get either 'DTS surround' on the display (but speaker output is shown to the surround back channnel, or DTS+Neo:6 (I always thought that Neo:6 was for stereo sources only). The only time i get the 'DTS es matrix' display is when playing a true DTS 6.1 matrixed soundtrack.
    Can someone please explain what i am actually getting and the differences between each setting on the 3805?
    Also, what is DTS enhanced Neo:6? (Is it something to do with this?
    By the way, got the B&W PV1 subwoofer at the same time! Superb :smashin:
  2. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    on my 3805 on a true 6-1 dts soundtrack mine shows dts-discreet which to my knowledge is correct, dte matrix is a 5-1 encoded dts signal mine also comes up showing dts+neo 6 on a 5-1 dts signal
  3. Pacha
    Pacha
    Oct 29, 2002
    134
    Thank's for reply however i'm fine with DTS ES discrete. I understand the format's themselves, just not quite sure i understand what the amp is doing at particular times, if anyone has a definitive answer please let me know.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,419
    2
    In a secret location with Jennifer Lawrence
    +9,115
    I've got a 3802.
    On mine when I am playing a DTS-ES discrete DVD, I get DTS-ES Discrete on the display, when I am playing any other DTS DVD, I get DTS matrix on the display which is taking the 5.1 channels and matrixing a 6th/7th mono rear centre channel.
    According to the DTS site, there is no such sound format as DTS ES matrix.
    http://www.dtsonline.com/consumer/technology/faq.php#faq89
    Greg
  5. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    There is indeed DTS ES matrix - the info on the DTS site doesn't contradict it either, but merely informs that DTS ES can support discrete 6.1. Even in discrete DTS ES, the rear surround channel is matrixed into the left and right surrounds to maintain backwards compatibility. The extra, discrete surround channel is subtracted from them upon decoding.
  6. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    also if playing a 5-1 dolby digital signal the 3805 comes up with dolby digital ex although its not a 6-1 encoding being fed, in i presume the display stays the same even if you have a 7-1 set up as the surround back would only be a mono signal sent to both speakers cant recall mine ever displaying dts-matrix my old 3802 did though
  7. Pacha
    Pacha
    Oct 29, 2002
    134
    EXACTLY! But does anyone know why you get 'DTS+Neo:6' on display instead of 'DTS es matrix'?
    Also, you can get sound output from the surround back channels when the dispaly reads 'DTS surround' - What is the difference?
  8. pragmatic
    pragmatic
    Nov 9, 2004
    12,119
    +1,647
    The neo algorithms are running on top of the DTS signal. Not sure why you would want that but my yamaha supports it too. Maybe if a source is in dolby digital 1/2.0/2.1 then it uses the algorthim to turn it into surround otherwise it would only be mono/stero.
  9. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,419
    2
    +9,115
    You get DTS Neo 6 on the display instead of DTS ES matrix because you must have selected that as the sound format on the amp. DTS Neo 6 is very much like Pro Logic 2. There must be a setting to change it back to DTS from the Neo 6, I know there is on my (old) 3802.
  10. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    not sure if there is a setting for dts-matrix there was no dd-ex setting on the 3802 it just showed up as dolby digital 6-1
  11. S H A D O
    S H A D O
    Mar 16, 2001
    10,290
    United Kingdom
    +1,571
    In the back of the manual should be a table telling you what modes you can use in relation to the input signals etc.
    You should be able to cycle through the various modes using the front panel, OSD or the remote. On mine it's a case of pressing the 6.1/7.1 Button and cycling through the options of Matrix ON, Matrix OFF etc etc. Calling up the Surround Parameters will give you access to the various decoding format choices and surround back outputs.
  12. Ian182
    Ian182
    Oct 15, 2002
    893
    46
    Leeds, West Yorkshire.
    +99
    Is this the same on the 2805 ?
    Reason I ask is the DVDs I've watched with DTS ES soundtracks (Return of the King EE being one of them) only show as DTS Surround on the display.........
    I've only got a 5.1 setup at the moment - will it only display as DTS ES if I connect a surround back speaker, or is there a way to do it without ?
    Thanks guys........
    Ian.
  13. pragmatic
    pragmatic
    Nov 9, 2004
    12,119
    +1,647
    I don't think you would get any benifit without the extra speaker(s) so maybe the software on the denon knows and does alow the dts or default to normal dts when the back speaker are not pluged in. I know i can force PL IIx on my yamaha even though i only have 5.1, but being a different brand and all it doesn't really answer your question.
  14. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    The 2805 will only only display DTS if you have a 5.1 setup as this is what is being broadcast.
    I have 6.1 on my 2805 and get DTS 6.1 discrete
  15. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    my old 3802 and my 3805 only show up dts es discreet if feed with a true 6-1 dts signal because its the only true dts discreet signal, no dts 5-1 signal should display discreet it should show up as dts es matrix
  16. Duffers0
    Duffers0
    Check that decoding is set to auto.
    This way the DVD flag will pick up DTS ES and provide the centre rear channel.
    Check that your normal surround mode is not NEO6 overriding auto selection.
    I have a Sony and leave 6th channel permanently matrixed ie for SKY non DVD material.
    But I have to change the 6th channel setting to Auto to ensure proper decoding of DTS ES material with descreet 6th channel
  17. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    if you leave the 3805 on auto on a 5-1 dts soundtrack it will go to dts+neo 6 which according to the book denon say is the best setting, i dont think it have anything to do with the input signal because on my 3805 it shows 6 seperate input signals and shows 7 on the signal output, will try to find out how to change output to dts es matrix next time i use it to see which i prefer
  18. Pacha
    Pacha
    Oct 29, 2002
    134
    Sorry guys, but John R1 seems to be the only one who really understands what i'm getting at.
    Let me explain again:
    If i play a 5.1 DTS soundtrack i get DTS+Neo6 on the display (with rear channel working) (Not sure if this is correct-my old 2802 would read DTS ES Matrix)
    If i play a 6.1 DTS ES Matrix disc (e.g Die Another Day) i get DTS ES Matrix on the display. (This is correct)
    If i play a 6.1 DTS ES Discrete disc (e.g. Seven) i get DTS ES Discrete on the display. (This is correct)
    Hope this explains what is happening a little better. Are there any 3805 owners out there who can explain this?
  19. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    played a dts 5-1 disc last night looked through the display it came up dts surround then it said dts matrix was on then it switched back to as normal dts+neo 6 so i still dont know if you can select dts-matrix for a 5-1 dts soundtrack will have a look at the auto flagging set up when i can find it again
