DTS dvds for under £3
Discussion in 'Shopping, Deals, Discounts & Bargains' started by captaineyecatch, Jul 21, 2003.
  1. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    HK online store DDDhouse are doing a load of DTS dvds for
    HK $25 +P+P
    See hereDDDhouse Click on the weekly sales link on the left hand side.
    Stock is limited - there are also a load of HK titles going cheap as well
    Titles are
    Cavemans Valentine - starring Samuel L Jackson
    Critical Mass - Classic action movie starring Treat Williams MUST be Seen by action fans for its use of Terminator 2 footage used in some of the action scenes.
    Desert Saints - Great thriller starring Keifer sutherland
    Get Carter - the stallone remake
    The Nameless - Superb spanish horror movie
    Series 7 - great reality killer show movie
    Venomous - another Treat Williams classic :rotfl:
  2. paul93
    paul93
    Dec 18, 2002
    289
    Waterlooville, Hampshire
    +6
    Hello
    I have always feel somewhat dubious about HK sites - except the cd-wow one. Have you ordered stuff before from DDD? What sort of delivery lead times do they have? Have you had any problems?
    Paul
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    Bought loads from them.. nicely packaged takes about a week.. just had below DTS, gosford Park DTS and Mimic 2 DTS in the last parcel!
    Matt
  4. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Dont worry DDDhouse are a Proper store and dont sell any bootlegs. The dvds that cdwow sell (the HK releases) are the same ones DDDhouse sell.
    Used them loads of times - had over 50 dvds from them over the past year and half. Just remember to keep your order under the customs limit of £18(including P+P) I normally order 3 discs at a time. Delivery is pretty quick usually 5 days max.
  5. paul93
    paul93
    Dec 18, 2002
    289
    +6
    Sounds great. I'll give them a try.
    Thanks for the help
    Paul
  6. tommyd
    tommyd
    I bought 6 DVDs from DDDhouse at the bigining of the year and 2 of them had perminant chinees subtitles.
    When I compained to then they jus said there was nothing they could do about it and They couldn't tell me which DVDs had perminant subtitles!
  7. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    +136
    They should be able to tell.. as it says on the box "English language with chinese subs" - as it does on the Below DVD rather than usually listing subtitles as a extra (which usually means that they can be turned on/off)
    Matt
