DTS & DTS 96/24, best way to ouput from player?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by museumsteve, Oct 31, 2004.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    7,958
    4
    Nth Hampshire
    +1,088
    Can anyone enlighten me as to which is the (supposedly) best way to play DTS and DTS 96/24 discs? I have a Pioneer 939-A and a Denon K-AVCA1SE. I have generally used optical and been happy with the results although I've started to see a few comments on the web that perhaps using six channel analogue output is preferable especially with DTS 96/24. Can anyone expand on this?
  2. recruit
    recruit
    I didn't think that was possible to do that with the analogue inputs?
    John :)
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,958
    4
    Nth Hampshire
    +1,088
    to do what? (or am I missing something)
  4. recruit
    recruit
    Yes sorry i was a bit vague, what i mean't was i did not think that you could run DTS 96/24 thru anologue inputs only digital :rolleyes:
    John :)
  5. Ovation
    Ovation
    There are very few players that can output DTS via analogue connections and I don't know of any that can output DTS 96/24. I believe only receivers/pre/pros are able to decode DTS 96/24 at this time.
  6. recruit
    recruit
    That is what i thought
    John
  7. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    i cant be sure, but from what ive seen, only optical or coaxial (the better choice) will pass a digital signal like DTS.
    The difference betwen Plain old DTS and 96/24 is not yet so obvious coz hardly any DVD players, and DVD's support this.
    I have yet to see a DVD player and a DVD disk for that matter that supports DTS 96/24.
    Same goes for something like DTS ES. I know in theory you only need 6.1 or 7.1 to use this but if the DVD player doesnt support it should it NOT work? even if the disk does and the amp does.??
    Its all so vague at the moment, and in the near future we are going to see new sound formats with new formats like blu ray and HD DVD, so DTS might end up dissapearing as it will be inferior to the newer formats.
    TBH i think that all these different "versions" of DTS and Dolby Digital are just to keep people thinking they need to buy a new amp or DVD player when in reality we dont.
  8. Ovation
    Ovation
    DTS 96/24 is a higher resolution (though still lossy) version of DTS and I believe it's primary purpose (at least in the short run) is to offer higher quality audio for music and concert videos on DVD. Peter Gabriel's new video compilation is encoded in this format and I look forward to hearing it. The 96/24 discs also have a regular DTS track to be compatible with the vast majority of gear out there. On this side of the pond, DTS 96/24 is becoming increasingly common on receivers and pre/pros and I suspect that most new DVD players are capable of passing the enhanced data stream via digital connections without too much difficulty.
  9. recruit
    recruit
    Ovation i have the new Peter Gabriel "Play" DVD and have to say the sound is very good and has impressed me i just wish there was more discs availible with DTS 96/24 the sound is similar to DVD-A it is very open sounding and nicer to listen to.
    John
  10. Ovation
    Ovation
    I think we'll see more in this new format as time goes by. Besides, it doesn't seem to suffer from all the self-inflicted problems that DVD-A and SACD have (though I've gone ahead and plunged into those waters too).
  11. recruit
    recruit
    I certainly hope so :cool:
    John
  12. Shenoizy
    Shenoizy
    Oct 24, 2005
    372
    +23
    The Region 3 version of Phantom Of The Opera has 24/96 DTS and it sounds fantastic.
  13. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Queen are really good for 24/96 which most player should output fine, the processing requirement for this mode are LARGE however and you need LOADS OF MIPS. The really limits it to the higher spec machines in general. There are also issues with the signal being sent at 48Khz and decoded at 96khz.
