DTS Doesn`t Work ?
Discussion in 'Desktop & Laptop Computers Forum' started by jacked, Aug 4, 2006.
  1. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    Hello Folks
    I`ve connected my pc to my home-cinema but any DTS track just works as Dolby Pro-Logic, not digital. The soundcard is a Creative X-Fi connected via the SPDIF Coax to a Denon amp. I`ve checked all the settings I know of and Dolby Digital works great but DTS doesn`t. When I use Theatertek it even says onscreen "DTS Bitstream" but then just plays in Pro-Logic !
    Could someone please point me in the right direction.
    Thanks very much.
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    It must be a setting within the set up menus on the amp, have you got it set to "auto detect"?
  3. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    Yes the amp`s on auto-detect, it just seems strange that Dolby Digital works fine but DTS only works in Pro-Logic.
  4. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    Anybody any suggestions ?:lease:
  5. Ajax
    Ajax
    Feb 4, 2004
    170
    I had this issue with my onboard SPDIF out. I tried everything but to no avail so bought an M Audio instead.
  6. sdu1975
    sdu1975
    Mar 12, 2005
    889
    Sheffield
    +18
    Same here.
    My On board spdif just stopped working so bought a usb sound card for £5 and DTS DD now work fine after messing with the amp inputs.
    Sorry just reread your post.
    What Denon is it and what input are your using?
    Mine wouldn't work on the DBS selection on the amp and yes I did match up the correct digi input.
    However when I swapped the input to the feed from my SKY+ box and it worked fine.
  7. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    Have you set DTS to onboard or external decoder on the Xfi card?
  8. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Start>COntrol PAnel>Audio HQ>Device Control>Decoder
    Set to SPDIF Passthrough
  9. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    The amp is a Denon AVC-A1SE THX Ultra connected via coaxial and set up for use on input VCR 2.
    In the X Fi Audio Console > Decoder tab DOLBY DIGITAL / DTS Bitstream Out is checked.
  10. russraff
    russraff
    Aug 1, 2000
    2,482
    Newcastle
    +87
    This is either an amp issue, which is unlikely if it is set to autodetect, or the software you are using. I know others have had good things to say about Theatertek, but I have always had reliability issues, especially with sound and general stability. Try, as an experiment, downloading either WinDVD or PowerDVD and set the audio options within the downloaded software to S/PDIF out. If the DTS bitstream still doesn't work then there is something wrong with the amplifier side of things.
    The X-Fi doesn't do any en/decoding to the signal if you have selected bitstream out (check tat both DD and DTS are set to external decoder from the blue audio console - I think you must have both DD and DTS set to the same option, but it's worth checking). Therefore I would suspect this is not the culprit.
    Russell
  11. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    I`m going to try PowerDvd on saturday and I`ve borrowed a long optical lead that will reach the pc, so I`ll try both those and see if I can figure out the problem.
    Thanks Russell.
  12. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    try a little free programme called "AC3+DTS XForm" it might work for you as it did for me. Mike
  13. jrh_james
    jrh_james
    Oct 18, 2004
    270
    Herts
    +12
    If you are getting pro-logic from a DTS track, then something on your PC has to be decoding the DTS stream and remuxing it to stereo, as otherwise you would get nothing but silence.
    Which audio codec is Theatertek using to process the DTS stream? Have you disabled DTS decoding in the audio codec properties (set it to pass-thru)?
    Do you have ffdshow installed, as the ffdshow audio codec was causing me problems with DTS decoding.
  14. jacked
    jacked
    Jan 7, 2004
    1,211
    83
    Bolton
    +422
    :clap: Finally got it working. Installed DTS X-Form as suggested and tried Theatertek again and DTS worked fine. I don`t know what it`s done but it solved the problem.
    A big thanks to Mike for that tip and everyone else who replied.
    Cheers guys.
