DT81 DAB Tuner
Discussion in 'Music Streamers' started by Maurice, Jun 10, 2004.
  1. Maurice
    Maurice
    Info on the Arcam site says "An FM tuner bypass function is included."
    What does this mean? :confused:
    Can the DT81 receive FM as well ?
  2. warrj
    warrj
    IIRC it means that you can daisy chain an FM tuner thru it. So that when you wish to listen to FM you just press a button the Arcam and the FM tuner's signal is passed thru to the tuner input on your amp.
    Regards,
    Jules.
  3. Maurice
    Maurice
    Thanks. :thumbsup:
