Question DSP UMIK-1 mic foam wind shield
Killak
Hello everyone
I've lost the foam wind shield from my Umik 1 microphone.
Will it make much of a difference if I don't have it or can anyone recommend any replacements?
DodgeTheViper
Where are you using the UMIK ?
DodgeTheViper
Then I doubt very much that you’ll need it.
Killak
Thank you very much @DodgeTheViper
I contacted DSP in the mean time and they quote £30 + Shipping from china for a replacement!! :confused:
I'll be running the Direct Software in a couple of days so hopefully it'll be ok without the windshield!
DodgeTheViper
Don't worry. In your circumstances you don't need it.
Just make sure you don't eat too many beans beforehand :D
nemesi54
I just got a umik-1 mic to start measuring my HT.
Do I use the foam shield during measurements?
Or just use the mic bare?
I haven't foumd anything about it.
Killak
If you got it use it but I don't think it make much difference if your using it indoors.
I use mine without the foam and it works just fine
nemesi54
Yes its indoors on Living Room HT.
Thanks @Killak
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
