DSP-AX750SE VOLUME Question
Discussion in 'AV Receivers & Amplifiers' started by jmsuch, Mar 29, 2005.
  1. jmsuch
    jmsuch
    Mar 11, 2004
    52
    Wirral
    I am not sure if my setup is working correctly. Can people who have this receiver advise as to average DB level. when playing a dvd for example on 5.1 I am at -35DB or lower. I seem to have to crank the volume up a long way before anything is really heard. Digi Sat is often around -45DB.
    Any thoughts?
    Room size average 15 x 13 FT
    Jools
  2. reservoir51
    reservoir51
    Common problem is the level settings of each speaker not being correctly set. Try pressing the 'level' button on the front panel and you should be able to cycle through the level settings for each speaker set and adjust each set accordingly. For my fronts, I have them set at +5dB, while my centre and rears are at +3dB and subwoofer at +3dB. Listening volumes range from -30 to -25 dB for music and -25 to -20 dB for movies.
    reservoir51
  3. Jackam
    Jackam
    There is no right or wrong if it sounds good. Unless everyone is listening in an anechoic chamber with matching ancillaries and the same source material, expect your setup to differ from everyone else's.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    This might well be normal and the same applies to my system; reason is that the signal from DVD has very high dynamics.
    If you think the overall volume becomes too loud (especially at night) activate the Dynamic Range Compression, sometimes also called "Midnight Modus" or similar. On Yamaha amps MAX means no compression, so choose the opposite setting.
  5. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    Your receiver is normal. It does go up to over 0db, remember. I can't remember exactly what it goes up to because I've never taken mine past +5db!!
  6. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Don't know what number it goes to - we listen at levels similar to those you listed - but we have got caught out by a child of a visiting friend who couldn't hear anything, so cranked it up to 'full max' (his words). He couldn't hear anything as it wasn't on DVD. We missed this until much later when we turned it on, found it wasn't set to DVD and switched it during some big film soundtrack music and found ourselves blown to the back of the room by the noise. Doesn't seem to have done any harm to the speakers (increadably) - and I always wondered what it sounded like if it was as loud as it could be - now I know!
    Greg
