DSP-AX1 configuration
Discussion in 'AV Receivers & Amplifiers' started by orenb, Dec 22, 2001.
  1. orenb
    orenb
    Hi I own the Yamaha DSP-AX1 and I need to configure it, the manual that came with it is not enough to properly enjoy the amp according to my speaker position.If you know how to or have some good links over the web I would appreciate it.
    Thanks,
    Oren
