DSP-A1 Volume Up/Down Problem
karlito
This is annoying.
My storming A1 has an intermittent volume control problem. When you up/down on the remote the screen says Up/Down... but the knob doesn't move and volume goes nowhere.
Sometimes it just comes back... sometimes turning the physical knob back and forwards a few times get's it back.
Anyone seen this before? Any ideas of a fix that doesn't involve disconnecting everything!!
Karl
General Skanky
I once had exactly that fault on an A2. Very intermittent.
Never did solve it even with a call to Yamaha tech support.
Not worth trying to fix either imho. With so many advances in modern units it's just not economical, the cost of fixing it would compete with its value on EBay.
Reiner
Sounds like a problem with the motorized potentiometer that controls the volume.
If it occassionally works maybe it just needs some cleaning, otherwise it could become costly.
General Skanky
Exactly what I told Yamaha. Didn't wash with them. However I'm sure a quick £50 across the palms would adjust that point of view.
karlito
This cleaning... is it something that one might do oneself? Slip off the casing and give it a quick blow?
As an intermittent problem I can 't imagine it's a part failiure... so maybe to an electronics engineer of which I know many as opposed to the Yamaha shop?
Thoughts?
Reiner
If you know about electronics you should be able to do it yourself. Use pressurized air (canned) only, nothing else.
Also check how the motor is connected to the potentiometer, if there is a rubber band maybe it got loose or started to rot. Disconnect the AC power before opening the unit!
General Skanky
The volume pot is a sealed unit from memory.
No chance of fiddling imho. A replacement required if it is that.
