DSLR Lenses
Discussion in 'Photography Forums' started by Pieeater, Jan 22, 2008.
  1. Pieeater
    Pieeater
    Jan 3, 2008
    213
    28
    Stockport
    +25
    A daft question because I ought to know such things but, do DSLR only lenses (I presume there are such things) need the focal lengths multiplying like 'regular' lenses that work on both SLR and DSLR?
  2. dfrear
    dfrear
    Nov 22, 2007
    654
    43
    +104
    I believe so, I think the digital editions simply employ a few more lense coatings and other things to produce better images, crop still affects them.
  3. dfrear
    dfrear
    Nov 22, 2007
    654
    43
    +104
    EDIT: Mods please delete.
  4. dfrear
    dfrear
    Nov 22, 2007
    654
    43
    +104
    Uh, I think something *may* have gone wrong when I posted that... server end that is.
  5. Pieeater
    Pieeater
    Jan 3, 2008
    213
    28
    Stockport
    +25
    Thanks for the clarification. That means buying a DSLR requires a new wide angle. :(
  6. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    I'm not aware of any differences in coatings etc.
    'DX' lenses, designed for cropped sensor DSLRS (ie all except the likes of the full frame Canon 5D and Nikon D3), only project an image circle big enough to cover the smaller sensor area. If you use them on a film SLR or a 5D/D3, you'll get vignetting. Conversely, 35mm film lenses are perfectly fine on a cropped sensor.
    Having said all that, yes dfear is absolutely right. If you put ANY lens on a cropped sensor DLSR, digital(DX) or 35mmfilm/full frame, the effective focal length is multiplied by 1.5 (Nikon), 1.6 (Canon) 2(Olympus) etc
