DSLR cheap Macro lens advice please
js474
Hi all,
I've just purchased my first DSLR - a Nikon D5000 - and am s-l-o-w-l-y getting to grips with it.
It came with 2 lens but I'm looking at a macro version also. Until I know more about both the camera & photography in general I'm keen not to spend hundreds, and wonder if something like this would be a suitable start?
52mm Close Up& Macro Lens for NIKON D3000 D5000 18-55MM | eBay UK
I appreciate that I won't get anywhere near the same quality, but as an introduction?
Thanks.
James
RobDickinson
Yep it will be an introduction.
Also look at extension tubes, reverse mount lenses , bellows and cheap real macro lenses like the cosina 100mmf3.5
Best close up lens to stick on a normal lens is canons 500D
S
shoalin kid
I can vouch for the raynox,have a 250 myself.a Decent cheap way to get into macro
shotokan101
D
Deleted member 27989
Still not hundreds but granted more than hundred is the sigma 70-300. Not bad at all for macro purposes.
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
