Dscaler??
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, May 30, 2002.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Is it right that Dscaler only works with AGP cards?
    So, I installed it but does not recognise my Geforce3Ti2000?
    I understand that you can install a WinTV card (PCI) which will exit via the Geforce card thus giving good SKY piccys...so how will Dscaler spot the WinTV card if it is not AGP and if it doesn't already spot my Geforce.
    Chris
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,739
    7
    2
    167
    Birmingham, UK
    +10,629
    mmm your post kind of implies that you don't understand how DScaler works.
    DScaler takes the input from a WinTV card (usually PCI) and converts the signal (from composite or S-Video) into a progressive scan output to the PC monitor via whatever graphics card you have.
    There is no point in having DScaler without a Win TV card.
    The typical situation where you would use it is when your HCPC is connected to your projector and you use it primarily to watch DVDs with. To watch other sources (VHS, TiVo, Sky, Laserdisc, games consoles), you use DScaler to output them to the same projector in lovely progressivescan.
  3. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    You're right Spectre, I don't know anything about Dscaler..But I am learning quickly thanks to help form good guys like yourself....so ta very much.
  4. jonny m
    jonny m
    Mar 22, 2002
    405
    Spectre
    I have a quick question, surely these wintv cards come with their own software to generate the required image on screen.
    Therefore why the need for dscaler??
    Asking out of ignorance.
    j
  5. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Most cards have hardware or software to help convert properly from interlaced to progressive scan, some don't do it at all (like the Hauppauge Nova-T cards), but in any event dscaler will nearly always do it much better (unless your into spending £20,000 pounds on a dedicated box to do it).
    LCD and DLP Projectors also can do it, but again Dscaler will almost always do it much better than the projectors own internal version.
    Go have a look here to see more.
