Dscaler backup
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, Jul 3, 2003.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I want to do a clean install on my HTPC and wonder if there is a way to backup all of my Dscaler settings and then restore them after the refresh?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I think you have to write them down mate, I don't think hanging on to the .INI file will save all the settings these days... could be wrong though.
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    How Eighties:rolleyes:
    I hope so;) anyone else?
  4. JohnAd
    JohnAd
    Mar 14, 2001
    362
    London
    +4
    The only 2 places settings are stored are Dscaler.ini and program.txt copying just these 2 files should capture everything. Ini file copying is late 80's at best :) one day we might get into a 90's registry solution and then probably in 2020 start using xml.
    John
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I liked the 80s!
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Cheers John, I'll give it a go.
