Dscaler and Component Problem
Gillykid
Hi All,
Well my HTPC setup has been working fine now for over 2 years, but i had to pull it apart to put a new floor down. When i put it back together there was disaster - the Dscaler picture has become distored.
Now any component input causes subtle horizontal rolling green lines moving upwards. Even with the input device off they are still visible. :confused:
Whats even weirder is when it does it. I have a AV-Tools component switcher matrix (no shouting, it works great) which provides the input. If i bypass it and plug either Sky or PS2 straight into the PC the picture is fine. However, if i plug the matrix into my LCD, it also works fine.
I dont get it - could it be a frequency problem?
Help!
G
