Dscaler 4 - girder and pronto files
Discussion in 'Desktop & Laptop Computers Forum' started by tryingtimes, Feb 21, 2003.
  1. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +548
    Surprisingly I'm struggling to find girder and pronto files for Dscaler 4.
    I've looked on girder.nl avs dscaler.com and remotecentral and had no luck!
    Anyone help?
    Alex
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,124
    Berks, England
    +45
    This is a simple early group I made when using a BT878 card
    If you've installed with the optional Dscaler developer filters then the filter commands may be slightly out. Also if you are using a non-bt878 capture card then the card specific menu items will also be slightly different.
    regards,
    Rob.
  3. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +548
    Thanks for that Rob
    I'll have a play - I'm going to be using the XCapture card so your point is noted.
    It's always nice to have a starting place with these even if by the end I've heavily customised it.
    Alex
